The rack and pinion system is the best here. Thor uses this method to great effect. I would have the ram directly attached to a toothed bar that meshes with a MOD 3 upwards gear.
BW: Shu!, The Honey Badger
I've been wondering about something like this, but I'm struggling to visualise how the rack will be secured. It seems like it will need some sort of linear slide/rail.
This sounds very cool. I read another post from Maddox about customising the ram by replacing it with a round bar rack and pinion, but I'm not sure how you're supposed to get a pneumatic seal with all those grooves cut out! Unless it doesn't fully retract but is a longer shaft that leaves all of the toothed section outside of the cylinder...
Custom pneumatic rams seem like a fairly specialist and expensive option though. I imagine you'd have to get this certified again for pressure too
Yeah I knew it didn't look the most efficient or practical for a back and forth rotation.
